Prusa link lose connectivity after print
MP3D
 MP3D
(@mp3d)
After updating Prusa link to the latest version, I started having this problem:
After finishing printing, it says "No Lan access" to be able to print again I have to turn the printer off and on.
This only started to happen after updating PrusaLink.
This is an Mk3S, the attached image shows the version that is running.
Opublikowany : 26/10/2023 5:19 pm
Tojik
(@tojik)
Member Moderator
RE: Prusa link lose connectivity after print
Hello, are you on Wi-Fi? if yes and you have not flashed the latest image, just updated through OTA, try the image. It tries to turn off WiFi power management, so it should not drop out
Opublikowany : 26/10/2023 7:07 pm
MP3D
 MP3D
(@mp3d)
Hi Tojik, yes i'm on Wi-Fi.
I did flash the IMG, i was using a very old version from beta testing 😛 but all was working correctly.
I have did check for update as you can see on the attach img, and the information i get is that the package is up to date, yesterday i did the OTA and did have an update that i did but the problem persist.
This is strange,
This post was modified 3 years temu by MP3D
Opublikowany : 26/10/2023 7:38 pm
Tojik
(@tojik)
Member Moderator
Let me reiterate. If you flashed the image that came with the 0.7.0 and did the OTA, you do not have the wifi power saving disabling thing. So one thing to try would be to get the latest image flashed.
Also, please send me the syslog from the bottom of that settings tab
Opublikowany : 26/10/2023 7:43 pm
