Prusa Connect corrupts SD card on sending file
Several days ago, I got a message stating that there was a new version of Prusa Connect (web based). I reloaded my screen and thus refreshed the software. Ever since then, I am getting frequent corruption of my USB stick upon adding a file to the download queue. When I examine the USB drive, it states that it must be reformatted. I do this and can then transfer data from my PC directly to the USB stick. If I then insert the stick into my Prusa Mini, I can print the file. The next time Prusa Likn connects to the Mini/ USB stick. the drive becomes corrupted.
What must be done?
RE: Prusa Connect corrupts SD card on sending file
Another issue is that, occasionally, when I transfer a file, I get a heap memory error and the machine needs to be rebooted. Interestingly, the file that was transferred is on the USB staick and can be directly printed on the Mini.
I just had this happen to me. I think it happens when my Prusa Connect file limit is reached.
Soo the printer corrupts the USB stick. The D card in the title is a typo then. This is known, however Connect does not access the usb stick directly, this is something the printer firmware does. Please pile on to the related github issue
link to the issue: [BUG] File uploads from prusaconnect wipe & corrupt usb drive. · Issue #3615 · prusa3d/Prusa-Firmware-Buddy (github.com)
