Printing problem from the print queue
[Risolto] Printing problem from the print queue
Fred
 Fred
(@fred-7)
Utenti
Hello,
everything is fine and there with first one printer then 2 printers now 3 printers with which I can no longer launch the printing from the rocket, but only by doing Reprint.
Otherwise good connection I can load files from prusaconnect, I do not understand where is the problem.
typeOriginal Prusa i3 MK3S
firmware3.11.0-4955
PrusaLink0.7.0.rc1
PrusaConnect SDK0.7.0.rc1
Postato : 21/11/2022 8:17 am
Fred
 Fred
(@fred-7)
Utenti
RE: Printing problem from the print queue
It works again no more filament according to the software I changed the spool in Filament and now it's ok.
So question the Filament function really works now?
Postato : 21/11/2022 3:23 pm
Tojik
(@tojik)
Utenti Moderator
Hi, no, filament tracking is very unreliable, there's too much guesswork for it to work correctly on the MK3
Postato : 21/11/2022 3:26 pm
Fred
 Fred
(@fred-7)
Utenti
Ok but there's really a problem I can't print anymore it sits me that I don't have any more filament
Postato : 21/11/2022 10:36 pm
Fred
 Fred
(@fred-7)
Utenti
The problem is real no more printing from the rocket only in "Job" resumes a printout already printed,
Can you please fix it? because it worked before
Postato : 22/11/2022 8:16 am
Jitka
(@jitka)
Utenti
When you add print to print queue. We look to print file metedata (if we have it) and if there is filament type or nozzle diameter we add conditions for printing and until this condition is satisfied we do not start the print. We should add some user way for better notification about this conditions and way to skip it.
For now you have to delete that file from print queue to be able to print other files.
Postato : 22/11/2022 8:51 am
Fred
 Fred
(@fred-7)
Utenti
So for the moment it is not possible to use the print queue?
Why does it work with some files?
Postato : 22/11/2022 10:06 am
Tojik
(@tojik)
Utenti Moderator
In order to work around the bug either have the Connect filament name match the one in the gcode exactly, or don't inform Connect about what filament you have loaded at all. Sorry there's no dialog box to allow you to force it.
Postato : 22/11/2022 10:32 am
Fred
 Fred
(@fred-7)
Utenti
Ok but it is no longer possible to access the filament administration
Postato : 22/11/2022 12:39 pm
Tojik
(@tojik)
Utenti Moderator
Can you send a screenshot of what is preventing you from telling connect there's no filament loaded?
Postato : 22/11/2022 2:35 pm
Sarka
(@sarka)
Utenti
Hello Fred, could you please confirm if you set your custom ABSfp filament_type in PrusaSlicer? Thank you and have a nice day.
Postato : 24/11/2022 8:32 am
Fred
 Fred
(@fred-7)
Utenti
Yes, but maybe not exactly the spaces or the shots where you need them.
But the other problem is that you can no longer administer the filaments in prusa Connect
Postato : 24/11/2022 5:06 pm
Fred
 Fred
(@fred-7)
Utenti
I removed the filament and it has been working ever since. Too bad it doesn't work with it.
Postato : 24/11/2022 5:07 pm
1 persone hanno apprezzato
