Printer reboots when sending command
Supercadad
(@supercadad)
I have manged to connect my first printer, however, when I try and send a command to test the connection such as 'home' the printer reboots.
Any suggestions?
Posted : 21/02/2022 12:06 pm
Supercadad
(@supercadad)
RE: Printer reboots when sending command
PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4)
Pi Zero 2
PrusaLink version
0.6.0
Printer type
MK3s (with hemera)
Printer UUID (you can find it in Printer detail page - address line)
Printer firmware version
3.10.0-4481 - Moded for hemera
PrusaSlicer version (if applicable)
Description of the bug, including steps to reproduce (if possible).
Posted : 21/02/2022 1:25 pm
Tojik
(@tojik)
Member Moderator
Hi, please try sending the logs. Go to PrusaLink local website, under settings there should be a section with logs. I am interested in the file starting with daemon from the day of the event (if not sure send more) If the file does not fit into the 10MB, consider zipping it. Logs tend to be well compressible.
This sounds almost like a HW issue. Make sure your pins are soldered and connected correctly. (There has been an error in the PrusaPrint manual for years).
Posted : 21/02/2022 4:23 pm
Supercadad
(@supercadad)
Update, It was hardware, there was a short between the Pi and the Rambo.
I know have the issue that the link works, but it will not communicate to printer connect.  I have deleted the printer from connect, logged into the IP of the printer again, but I am not greeted with the wizard to re connect back to prusaconnect.
Posted : 21/02/2022 4:29 pm
