Print stops and resumes
Sir Printalot
(@sir-printalot)
https://forum.prusa3d.com/wp-content/uploads/2022/07/VID_20220712_190130.mp4
See video. The setup has been working without problems for 6 months before this started.
api
2.0.0
hostname
Orange
firmware
3.11.0-4955
server
0.6.0
text
OctoPrint 1.1.0
sdk
0.6.0
frontend
3.5.0
Any idea how to fix?
Postato : 09/05/2023 8:17 am
Tojik
(@tojik)
Utenti Moderator
RE: Print stops and resumes
Hi, I do not see any video attached. You can try updating to the 0.7.0 RC3 from github, but apart from that I have no clue without poking atound with debug logs on. Might be the pi overheating as we get into the warmer part of the year, but that's just a guess.
Postato : 09/05/2023 2:21 pm
Sir Printalot
(@sir-printalot)
Hi Tojik,
Thanks for the help.
I updated the SD card but now it seems like there is an issue with the API key.
I can control the printer though prusa link, but I am not able to link it to Prusaslicer with the API key. I get the following error message:
Error uploading to print host:HTTP 403: Bad X-Api-Key.
Thanks in advance.
Postato : 14/05/2023 7:12 pm
Tojik
(@tojik)
Utenti Moderator
Yea, we kinda hid it, we would like you to use the digest auth. You can set PrusaSlicer to use it. Here's a gif https://forum.prusa3d.com/forum/postid/655135/
You still can generate an api key. It's in Link under settings.
Hope this helps 😉
Postato : 14/05/2023 7:39 pm
Sir Printalot
(@sir-printalot)
0.7.0 RC3 is installed, but the problem persists. See video below.
https://www.youtube.com/shorts/iFK_a0_Lcvc
Postato : 15/05/2023 5:42 am
Tojik
(@tojik)
Utenti Moderator
So is this an absolutely squeaky clean image right off the imager? I am thinking another process eating resources or something. Can you get into ssh to launch htop and see the CPU usage? Is this a special G-Code? Or is this straight from prusaslicer?
If you could get into ssh and run "prusalink -r restart" then start a print that exhibits this behavior and send me the log from thet session afterwards, that would help a lot.
One more thing that comes to mind, try removing the SD card from your printer if here's one inserted. But I am really not sure what did it cause. The pauses are weirdly long. For all I know it could be a sneakily placed G4 in the gcode itself. So if you can send the gcode, that would be great too.
Thank you
Postato : 15/05/2023 3:03 pm
Sir Printalot
(@sir-printalot)
It was 100% clean.
I used the G-code on the printer with an Sd card and it worked just fine.
Anyways, it works now. I updated the firmware on the printer and reflashed it with the new 0.7.0.
Thank you so much for the help, Tojik. Really appreciate it.
Postato : 08/06/2023 1:23 pm
Tojik
(@tojik)
Utenti Moderator
Whew, glad issues are going away on their own 😀
Postato : 08/06/2023 2:04 pm
