Print stopped in the middle, prusalink offline
Hi
PrusaLink 0.6.1@Raspberry Pi Zero W (not 2 W)
In the "middle" of the print suddenly print stopped, printer went offline on connect.prusa and became unavailable through direct access through local network. After reboot it did not connect to WiFi. What logs should I check and what logs should I provide you for analysis of the incident.
RE: Print stopped in the middle, prusalink offline
Hi, well if you can get the logs, please send the file from /var/log/syslog
I'm interested in what the condition of the SD card is. Can you write to it?
Thanks
Not sure about SD card - it seems to be quite new, however I don't recall when I bought it - I was using it with 3d printer before. It's ADATA 32GB HC1. I'll look for another SD card and try with 0.7 version. Print stopped around noon Nov 2
Wow, nice graph the gnome disk utility makes, never known it had such an awesome feature. Anyway, sorry, the incident looks like a loss of power on the RPi side. I would try and wiggle the pi in its slot while the printer is on, to see whether it might be a bad connection at one of the power carrying pins. If that's the case, try re-soldering the pins or remove the Pi from the printer pin slot and connect it to power and to the printer through USB. Sorry it's giving you trouble.
TBH seems like major pi failure - I'm having trouble booting it ATM. It doesn't even indicate power no matter how I connect it.
I'd go for a fresh rpi os on another SD card. Any raspi can act dead when it can't read the SD.
