Print starts when I hit "Set ready" even though I never put anything in the queue
Scott Gartner
(@scott-gartner)
This is the second time in a week that I hit Set ready and something immediately started to print even though there was nothing in the queue.  I don't use the queue, I print everything one-off (so far, anyway).  I had just uploaded a new file, but it started printing the last thing that I printed (so the second-to-last file I uploaded).  I always click the button that says "Copy to printer" never "Add to print queue", I'm very careful about which button I hit.  I am the only person using the printer, so someone else can't have put it in the queue.  When this happens I immediately change to the Print queue tab and there has never been anything in the queue.
Postato : 18/05/2024 11:23 pm
Scott Gartner
(@scott-gartner)
Definitely adding files to the queue by itself
It happened again and I was paying very close attention this time.  I had printed a couple of small tests, I started a new print at the printer (that I uploaded using connect, but did not add it to the print queue).  While the new print was running I went back into connect and looked at the queue page and the previous print was in the queue.  I had very definitely not put anything in the queue.  I had only been uploading then hitting print in connect, and then this last print at the printer itself.  Definitely some bug in connect.
Postato : 01/06/2024 8:53 am
Coloneljesus
(@coloneljesus)
Utenti
RE: Print starts when I hit "Set ready" even though I never put anything in the queue
I've noticed the same behavior on my machine. Could it be a debouncing issue with the LCD interface?
Postato : 05/07/2025 6:31 pm
Zippy
(@zippy)
I have same behavior almost every time regardless whether i press ready on lcd or through joystick button. Seems like no solution to this issue
Postato : 18/02/2026 9:57 pm
