print preview images
Lehnen
(@lehnen)
Membre
Good morning, I don't see any print preview images, only question marks. should that be so?
Best Answer by ml23:
You need to specify the image dimensions for G-Code thumnails in PrusaSlicer in the printer settings like this
Repetier-Server, Prusa Mk3s and Prusa Mini+
Publié : 19/02/2022 5:09 am
ml23
 ml23
(@ml23)
Membre
RE: print preview images
Publié : 19/02/2022 8:45 am
1 personnes ont aimé
Tojik
(@tojik)
Membre Moderator
Also do not expect previews from the SD card. It's impossible to read the file contents from there for me.
Publié : 19/02/2022 1:18 pm
Lehnen
(@lehnen)
Membre
With the tip of ML23 I also see the thumbnails on the SD kart
Publié : 19/02/2022 1:35 pm
Tojik
(@tojik)
Membre Moderator
There is no way those can work from the printer SD. At most the files from raspi can get paired to those from the SD, if that happens, i'd consider calling that a bug.
Publié : 19/02/2022 2:17 pm
Lehnen
(@lehnen)
Membre
I used an x-y-z calibration cube, it's just very small, it's actually displayed with a 1MB file, it doesn't work anymore, I've tried to reproduce it, but it doesn't work, you're probably right that it's a bug
Publié : 19/02/2022 2:38 pm
