Print just stops with Prusa connect
Hi
My printer just stops the print, the last 3 print was stopped at the same point when using Prusa connect and not done.
There are a lot of errors in the log, but I don't see anything that would stop the print.
The print stopped about 6:54, but the print was only 85% done.
Everything is updated 🙂
API 2.0.0
Hostname prusalink
Firmware 3.14.0-8066
Server 0.8.1
Text PrusaLink 0.8.1
SDK 0.8.1
Frontend 3.12.0
Printer MK3S
Pi3s
ug 03 06:05:28 prusalink systemd[1]: Starting apt-daily-upgrade.service - Daily apt upgrade and clean activities...
Aug 03 06:05:30 prusalink systemd[1]: apt-daily-upgrade.service: Deactivated successfully.
Aug 03 06:05:30 prusalink systemd[1]: Finished apt-daily-upgrade.service - Daily apt upgrade and clean activities.
Aug 03 06:05:30 prusalink systemd[1]: apt-daily-upgrade.service: Consumed 2.055s CPU time.
Aug 03 06:06:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:08:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:10:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:12:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:14:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:16:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:17:01 prusalink CRON[9268]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Aug 03 06:17:01 prusalink CRON[9269]: (root) CMD (cd / && run-parts --report /etc/cron.hourly)
Aug 03 06:17:01 prusalink CRON[9268]: pam_unix(cron:session): session closed for user root
Aug 03 06:18:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:20:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:22:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:24:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:25:01 prusalink CRON[9401]: pam_unix(cron:session): session opened for user root(uid=0) by (uid=0)
Aug 03 06:25:01 prusalink CRON[9402]: (root) CMD (test -x /usr/sbin/anacron || { cd / && run-parts --report /etc/cron.daily; })
Aug 03 06:25:01 prusalink CRON[9401]: pam_unix(cron:session): session closed for user root
Aug 03 06:26:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:28:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:30:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:32:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:34:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:36:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:38:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:39:01 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:01 prusalink systemd-journald[246]: Data hash table of /run/log/journal/87d03193b2d1493293762476ca005fca/system.journal has a fill level at 75.0 (1573 of 2097 items, 1208320 file size, 768 bytes per hash table item), suggesting rotation.
Aug 03 06:39:01 prusalink systemd-journald[246]: /run/log/journal/87d03193b2d1493293762476ca005fca/system.journal: Journal header limits reached or header out-of-date, rotating.
Aug 03 06:39:02 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:04 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:05 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:06 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:07 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:08 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:09 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:10 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:11 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:12 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:13 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:14 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:39:15 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:40:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:42:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:44:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:46:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:48:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:50:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:52:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:54:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:54:40 prusalink prusa.link.printer_adapter.job[1292]: INFO: Job ended {job_ended():118}
Aug 03 06:54:40 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:54:41 prusalink connect-printer[1292]: INFO: Got unexpected telemetry response (409): {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {parse_command():701}
Aug 03 06:54:41 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:54:45 prusalink connect-printer[1292]: INFO: Got unexpected telemetry response (409): {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {parse_command():701}
Aug 03 06:54:45 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:54:49 prusalink connect-printer[1292]: INFO: Got unexpected telemetry response (409): {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {parse_command():701}
Aug 03 06:54:49 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:54:52 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:54:53 prusalink connect-printer[1292]: INFO: Got unexpected telemetry response (409): {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {parse_command():701}
Aug 03 06:54:53 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:54:58 prusalink connect-printer[1292]: INFO: Got unexpected telemetry response (409): {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {parse_command():701}
Aug 03 06:54:58 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:55:01 prusalink connect-printer[1292]: INFO: Got unexpected telemetry response (409): {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {parse_command():701}
Aug 03 06:55:01 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:55:05 prusalink connect-printer[1292]: INFO: Got unexpected telemetry response (409): {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {parse_command():701}
Aug 03 06:55:05 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:55:09 prusalink connect-printer[1292]: INFO: Got unexpected telemetry response (409): {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {parse_command():701}
Aug 03 06:55:09 prusalink connect-printer[1292]: WARNING: {"message": "The destination folder already contains a file with the given name", "forcible": true, "code": "CONFLICT_DOWNLOADED_NAME"} {loop_step():833}
Aug 03 06:56:22 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Aug 03 06:56:37 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:38 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:39 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:40 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:41 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:42 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:43 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:44 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:45 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:46 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:47 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:48 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:49 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:50 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:51 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:52 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:53 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:56:54 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: Authorization header not found {check_digest():36}
Aug 03 06:57:34 prusalink prusa.link.web.lib.auth[1292]: INFO: Digest: nonce value not match {check_digest():47}
Veröffentlicht : 03/08/2024 5:33 am
RE: Print just stops with Prusa connect
I will now thy to print from SD card and see if that works.
Veröffentlicht : 03/08/2024 5:35 am
In my video feed i can see that the printer stopped 06:54:40.
For some reason the print was stopped from prusa link.
Veröffentlicht : 03/08/2024 5:51 am
