Ghost print entries (previous title attracted spam)
Fred
 Fred
(@fred-7)
Hello,
the prusa connect site has been upgraded to FE v.1474BE v.0.10.0-50DB v59
Since then it adds a job... here is the screen
Where does this come from?
Posted : 09/03/2022 10:15 pm
Fred
 Fred
(@fred-7)
RE: New job without doing anything
continued second file
Posted : 09/03/2022 10:16 pm
Tojik
(@tojik)
Member Moderator
Hi, would you please try and find what lead to its creation in the log tab? Thank you
Posted : 10/03/2022 8:19 am
Fred
 Fred
(@fred-7)
How?
Posted : 10/03/2022 9:09 am
Fred
 Fred
(@fred-7)
since there is the new version of prusaconnect
Posted : 10/03/2022 9:15 am
Tojik
(@tojik)
Member Moderator
The log should be looking something like this
Posted : 10/03/2022 10:39 am
Fred
 Fred
(@fred-7)
Voici
Posted : 10/03/2022 11:31 am
Fred
 Fred
(@fred-7)
And here's another question: why does it suddenly flow at 95% when the printer says 100%?
Posted : 10/03/2022 11:36 am
Fred
 Fred
(@fred-7)
Printer photo suite
Posted : 10/03/2022 11:37 am
Fred
 Fred
(@fred-7)
Also here
Why does it say STATE UNKNOWN with the same information as the current printout?
Posted : 10/03/2022 11:43 am
Tojik
(@tojik)
Member Moderator
Sorry, I didn't check if the info I need is actually in there, welp, I checked and mistook command id for job id. Ideally, I'd like to see what was happening around the time Connect registered this ghost job.
Flow is 95% by default, flow isn't the speed multiplier. There is a bug however, where the reset defaults in connect sets flow to 100%
I have limited knowledge about how jobs in Connect work, so I cannot answer the last one
Posted : 10/03/2022 2:48 pm
Fred
 Fred
(@fred-7)
Here is
Posted : 10/03/2022 3:16 pm
Fred
 Fred
(@fred-7)
Otherwise the printing times are no longer fair either.
Posted : 10/03/2022 3:17 pm
Tojik
(@tojik)
Member Moderator
Can't see in what state was it before and how it got there. I assume it somehow got into printing without actually printing, but don't know how
Posted : 10/03/2022 3:23 pm
kez
 kez
(@kez)
Just had exactly the same behaviour on one of my printers.  The prior job shows "State Unknown" despite having finished correctly.  There is then a "Print job #93" which was not something ever sent to the printer.
The only entry in the log for the printer in Prusa Connect that matches that time is this:
2:56:11 PM
STATE_CHANGED
READY
MARLIN
new state from event{"checked":false}
Posted : 10/03/2022 9:32 pm
McBig
(@mcbig)
Flow is different value that speed. On LCD on Info Screen, there is only speed value. Flow is somewhere in support menu when you printing.
The UNKNOWN state is typical for situations, when Connect don't know, how job was finished (printer was offline, connect was offline), and of course, when we have some bug in code. So please, can you tell us, if is possible, than your printer was offline, when job was finished?
Posted : 11/03/2022 1:17 pm
Fred
 Fred
(@fred-7)
The printer was not offline, it worked until the prusa connect update, what you say is not consistent
Posted : 11/03/2022 6:20 pm
