multiple features not functional
Fred Durand
(@fred-durand)
Utenti
Hello.
At that time, i am running 10 of my printers with prusalink / prusa connect.
- PrusaLink type (Raspberry Pi Zero / Pi 3 / Pi 4): pi zero W & pi zero 2 w
- PrusaLink version: all are the current  0.6.0-HOTFIX
- Printer type: i3 mk3s+
- Printer UUID: various
- Printer firmware: all are the current firmware: 3.10.1-4697
- versionPrusaSlicer version (if applicable): up to date: 2.4.1
Description of the bug, including steps to reproduce (if possible):
I am mainly using chrome as browser, but I also tried with Edge, and got the same result.
I tried with 3 differents computerts, running win 11 or 10, same result.
- thumbnails doesn't show up in prusaconnect. didnot checked with prusalink, as I don't want to use this aprt of this interface. Yes, I did add the 400x400 thing in prusaslicer for each of my physical printers.
- I don't have any option of uploading g-codes through prusaconnect. I can do it through prusalink, and through prusaslicer / physical printers
not really a feature, but I see it as a bug: sometimes, one of my printer shows NO IP. Wifi signal is very strong as I added a wifi emitter in the very same room. If I wait, nothing changes. If I restart, perfectly working again.
Postato : 01/04/2022 9:42 am
Tojik
(@tojik)
Utenti Moderator
RE: multiple features not functional
Hi, sorry, the 0.6.0-HOTFIX is not actually the last one, but I'd encourage you to wait around a week for 0.7.0
Turns out adding "-HOTFIX" to the version broke a version check in Connect but passed API validation, so my test - run it, seems to work fine, push it out, failed to catch it.
The thumbnails issue should be resolved in 0.6.1
The upload should work in 0.6.1, but I've seen reports of it working just intermittently.
The WiFi can be spotty, there are contacts for soldering a wifi antenna to the pi. It does not help that it's so close to the Amel chip - I've heared that's the reason 8bit will never pass electromagnetic interference certification in the USA, so you can't just buy your printer in a store like everything else, maybe just a speculation. The only "real" option so far is an ethernet dongle, as ugly as that sounds :/
Postato : 01/04/2022 11:32 am
Fred Durand
(@fred-durand)
Utenti
Thanks for the reply.
I also noticed the other reply in the other topic.
I have a lot of respect for people who can admit their errors, so you have it all.
thanks for working at making it better.
as you adviced, I'll wait for 0.7.0 which should be a game changer for me at that point.
Postato : 01/04/2022 11:39 am
Tojik hanno apprezzato
Eric E
(@eric-e)
Utenti
+1
Posted by: @fred-durand
Don’t trust forum advice.
Postato : 14/04/2022 3:49 pm
