MINI firmware update stuck on "waiting"
HolisticDeveloper
(@holisticdeveloper)
I want to try out the new OTA firmware update capabilities with Prusa Connect on my MINI+. It is currently running firmware 5.1.0 and it is connected via ethernet.
When I open Prusa Connect, it shows that version 5.1.2 of the firmware is available, but when trying to transfer the firmware it just seems to get stuck.
Repro steps:
  1. Sign in to Prusa Connect.
  2. Go to the printer dashboard.
  3. Click the up arrow icon next to the Firmware version display.
  4. In the 'New firmware update is available!' modal dialog, click Transfer.
  5. Note the status pop up in the bottom corner that says that the firmware was successfully added to the transfer queue.
  6. Wait a while...
Expected results:
Firmware is transferred to the printer and I am prompted to restart it.
Actual results:
The firmware file is listed under the Current transfers section of the dashboard. The status says "File transfer to Prusa Connect completed successfully" but over the middle of the progress bar it just says "Waiting..." and nothing else happens.
UUID: cab0fbe8-b78d-47c8-a0a5-a43b6e15e0a9
I also use OctoPrint with this printer, in case that has any impact.
Posted : 21/12/2023 2:39 am
