lost connection internet/link
Seite 2 / 2
Patrick.b
(@patrick-b)
RE: lost connection internet/link
Posted by: @balu-2
We are suspecting that the problem is not your PC that is disconnecting, but the PrusaLink machine.
PrusaConnect is a cloud service. Which will work if your PC has internet access.
If PrusaLink gets disconnected, it will not help if your PC has a network connection.
agree , link is local so..
Veröffentlicht : 02/03/2023 10:53 am
Patrick.b
(@patrick-b)
here result 1st test prusa connect and prusalink open :
1, ping 8.8.8.8 -t ; test : octet=32 / temp=12ms / TTL=117
2, ping <insert-prusalink-ip> -t TEST : octet=32/ temp=2 or 4 or 8 or 3ms /TTL=64
3, ping <Router-ip> TEST:octet32 / temp=1ms / TTL=128 all is fine 4send 4 receive normal
2nd test i close all firefox windows then re open prusaconnect 1st and prusalink too = connect open as usual , link not as usual too 🙄
1, ping 8.8.8.8 -t ; test : octet=32 / temp=12ms / TTL=117 SAME
2, ping <insert-prusalink-ip> -t TEST : DEAD (impossible to join host )
3, ping <Router-ip> TEST:octet32 / temp=1ms / TTL=128 all is fine 4send 4 receive SAME
voilà  1 is ok 3 is ok 2 nope..
Veröffentlicht : 02/03/2023 3:26 pm
BloodyT
(@bloodyt)
Mitglied
Ok, there we go.
Now we know somhow your prusalink lost Connection
Veröffentlicht : 02/03/2023 4:37 pm
Patrick.b
(@patrick-b)
exactly
idea ?
Veröffentlicht : 02/03/2023 5:03 pm
BloodyT
(@bloodyt)
Mitglied
Thats tough to tell from distance… Check the Logs from your prusalink if its rebooting or just loosing wifi. If it is wifi, you have to check your signal, like with any other wifi device
Diese r Beitrag wurde geändert Vor 3 years 2 mal von BloodyT
Veröffentlicht : 07/03/2023 5:42 am
Seite 2 / 2
