Home Assistant integration: "Only PrusaLink API v2 is supported"
Mathieu
(@mathieu-2)
Hello,
Home Assistant integration is failing because it only works with API v2 (Mini printers).
Is it possible to align PrusaLink API to v2 so that /api/version can report 2.x.x and then be usable on Home Assistant ?
Last prusalink returns:
  "api": "0.9.0-legacy",
  "server": "0.7.0rc3",
  "original": "PrusaLink I3MK3S",
  "text": "PrusaLink 0.7.0rc3",
  "firmware": "3.11.0-4955",
  "sdk": "0.7.0rc3",
  "capabilities": {
    "upload-by-put": true
  "hostname": "PrusaLink"
Currently, HA integration is limited to Mini printers because of that, but even if the version were to be updated, it could fail because API Key is deprecated (which is a ongoing PR on HA side)
Refs:
  1. Integration: https://www.home-assistant.io/integrations/prusalink/
  2. Feature Request on HA to support more than v 2.x.x API: https://community.home-assistant.io/t/prusa-3d-printers-support/550070
  3. Issue explaining the problem: https://github.com/home-assistant/core/issues/86230
  4. Related discussion in Prusa forum about the problem: https://forum.prusa3d.com/forum/user-mods-octoprint-enclosures-nozzles/prusalink-and-home-assistant/paged/2/
  5. A PR to change HA prusalink lib to use digest auth besides other changes: https://github.com/home-assistant-libs/pyprusalink/pull/25
IMO it would be far easier if Prusalink could provide a similar API for HA consumption for all printers, even if HA library opens the door for more API/version support,
Thanks!
Veröffentlicht : 20/03/2023 12:57 pm
