Firmware bug?
3DLada
(@3dlada)
Firmware bug?
hi after setting rpi4 prusa link this is what iam getting my mk3s+ is on latest firmware
any ideas what is wrong?
Publié : 13/03/2022 12:19 pm
DanielAttia
(@danielattia)
Membre
RE: Firmware bug?
Have you created the config file for PrusaLink to work over USB on your RPi4? (see this post)
Also, make sure that the RPi port is disabled in settings on your Prusa, as PrusaLink won't be able to communicate with the printer (it's intended for use with the RPi Zero).
If you still run into issues, try and reflash your SD card and set up the config file before connecting and turning on your printer... as the order of operations may help your setup process work as intended.
Publié : 14/03/2022 1:15 am
Tojik a aimé
Tojik
(@tojik)
Membre Moderator
RE: Firmware bug?
Hi, yes, if you want to use PrusaLink through USB, you need to configure it first. I don't think there's a need to re-flash the SD a simple restart should be enough
Publié : 14/03/2022 8:45 am
