File Transfer Error When Using Prusa Connect
Stránka 1 / 2
gurgleapps
(@gurgleapps)
Only started happening today I get file transfer error on every print from Prusa Connect to my MK4. It works on my Mk3s+ and works through Prusa Link both from the slicer and from drag and drop on the web interface. So it's only Prusa Connect that fails every time.
I've restarted, turned on and off, re-flashed firmware, I also tried from another browser and machine and switched out the USB stick.
Anty ideas?
Napsal : 13/02/2024 6:22 pm
Fallon
(@fallon)
RE: File Transfer Error When Using Prusa Connect
I had that issue a few days ago. File would upload from PrusaSlicer to PrusaConnect. Then it would sit there & fail to go from PrusaConnect to the printer. I think manually uploading to PrusaConnect failed as well. Rebooted the printer a few times to no avail. I gave up & came back the next day. Worked fine then. I only tried on my XL & not the MK3 with a Pi for PrusaLink though.
So no help on why, but at least you aren't alone with some issues recently.
Napsal : 13/02/2024 9:13 pm
1 lidem se líbí
Daniel L.
(@daniel-l)
I have the same problem since Tuesday. Every time I upload a file from PrusaSlicer I stuck mid upload.
Napsal : 16/02/2024 10:55 am
MVH3032
(@mvh3032)
Yup me too getting the same problem. Control works fine e.g. I can switch the printer heatbed on whilst the file is 'waiting'
I first noticed it last night. File uploaded to Connect then just sat 'waiting' to send to printer. Sending via PrusaLink was fine. Today am not at home so cannot use PrusaLink so trying to send another file via Connect to start it printing remotely and again have the waiting message.
Napsal : 27/02/2024 1:32 pm
iibex
(@iibex)
For me the same problem.
Any update available?
Napsal : 03/04/2024 8:28 am
iibex
(@iibex)
I updated to the latest firmware 5.1.2. Its solved now.
Posted by: @iibex
Napsal : 04/04/2024 6:04 pm
Semi
 Semi
(@semi)
Same issue here.
It works every now and then, and if I look at my queue, I have things loaded but with an error of "this file doesn't exist on the printer".
Manually copying the files to the USB works fine at least.
This is more annoying than the erro message that there was a transfer error, but the file is still there. Manually starting a print with the same file that supposedly failed works.
I haven't tried with PrusaLink yet, but will once my printer is free again.
Napsal : 06/04/2024 9:06 pm
1 lidem se líbí
FIXAR
(@fixar)
The same problem, printing works only by copying file directly to usb
This post was modified před 2 years by FIXAR
Napsal : 20/06/2024 12:50 pm
Mieszko
(@mieszko)
Same problem here. Prusa mini works fine, but MK3S+ is having issues. I can home it via Prusa connect, but file transfer is impossible.
Napsal : 23/06/2024 9:17 pm
Hyperion0
(@hyperion0)
Same issue on XL single tool. I've tried updating firmware slicer software, resetting printer so far nothing has been helpful.
This post was modified před 2 years by Hyperion0
Napsal : 04/07/2024 1:45 pm
flintridge
(@flintridge)
I have a Prusa XL 5T and i have this issue as well.  I found a reddit post about it and two options fixed it, new usb assuming it is bad or renaming the  file with less keys.   For me there seems to be a character limit the Prusa Connecct will take before it will not send it to your usb.  It always seems to transfer to Prusa connect fine but when it tries to send it to the printer (usb) it fails.
Napsal : 31/07/2024 2:49 pm
1 lidem se líbí
Corenth
(@corenth)
I had this problem as well. In my case it was an issue with a duplicate name on the UBS stick. I had a folder on the stick that had the same name as the file I was trying to send to the printer.
Napsal : 04/08/2024 7:26 pm
James Bray
(@james-bray)
I had the same problem today.....shortened the name of the file and all was well.
Napsal : 11/08/2024 12:44 am
ThisGuyIsBrad
(@thisguyisbrad)
I was having this issue when I was trying to upload a file with the same name. When I deleted the existing file and tried again, it worked.
Napsal : 12/08/2024 6:33 pm
1 lidem se líbí
Mr.Yutz
(@mr-yutz)
Shortening the file name worked for me too.
Napsal : 22/08/2024 1:53 pm
MartinSpajaard
(@martinspajaard)
Deleting all older files which were uploaded to the printer (XL 5T) did the job. There just was no memory space enough.
Napsal : 26/08/2024 8:11 pm
vader14641
(@vader14641)
Hi!
Posted by: @thisguyisbrad
Thanks! This solution helped me here. I sent the new order with a new name instead of the old one.
Napsal : 28/08/2024 2:21 pm
Lazarith
(@lazarith)
Same here.  Thanks for the info.  Hopefully they will get it resolved soon.
Napsal : 30/08/2024 3:21 pm
JeffT
(@jefft)
Had same issue where file would upload from Prusa slicer to connect but would not transfer to printer. After  trying a lot of suggestions with no luck. I eventually found out that a corrupt file on the flash drive prevented any files from transfer from Connect to printer. I re-formatted the usb drive to get rid of  corrupt file that could not be deleted from usb. As soon as I plugged usb back into printer the file transfer started and print began. Hope this helps
Napsal : 13/12/2024 9:40 pm
1 lidem se líbí
gooner
(@gooner)
I get the same error. However, it is uploading the file. If I wait and select confirm when it finishes  there is no error. It appears that you're not supposed to confirm until the transfer is finished. I don't know why it throws and error and wonder why is just doesn't say not finished.
Napsal : 18/12/2024 2:35 pm
1 lidem se líbí
Stránka 1 / 2
