Error 65 from PrusaSlicer
MedDim
(@meddim-2)
Utenti
I can ping all my prints with no packet loss, the test in prusa slicer shows a good connection, I can access the web page for PL but when uploading from PrusaSlicer I get an Error 65 nor can I upload to the web page.
Postato : 08/04/2022 12:42 am
Tojik
(@tojik)
Utenti Moderator
RE: Error 65 from PrusaSlicer
Hi, this is awkward, I do not know what error 65 is. It's not one of mine, so I need to know what component gave it. Could I get a screenshot of the error?
Can you try uploading by dragging and dropping the file onto the upload box in the PrusaLink local web interface? Trying to figure out if the error is from PrusaSlicer, or somewhere within PrusaLink..
As "always" if more back and forth is needed, I prefer our Discord server because it has push notifications.
Thank you
Postato : 08/04/2022 8:13 am
MedDim
(@meddim-2)
Utenti
I'll message you on discord! And post a resolution here for anyone else that runs into the issue.
Postato : 08/04/2022 2:24 pm
DonSwanson
(@donswanson)
I've had similar issues in the past (Error 65), and it was because I needed to explicitly add ` https://` to the beginning of the printer "hostname" field. Not sure if it's the same issue you are having.
Postato : 16/04/2022 1:14 am
SM26 hanno apprezzato
Tojik
(@tojik)
Utenti Moderator
Yeah, I've read about those for octoprint. The issue is presumably caused by curl. It tries to re-send a chunk of a file, it needs to "re-wind" to the position from which it wants to send, but it fails during the rewind. Idk what the https does to help the situation, so i'm stuck at the moment.
Postato : 19/04/2022 3:16 pm
