Connect.Prusa3d.com appears to be having issues
Dsk001
(@dsk001)
Utenti
Anyone else having issues logging in or seeing the page properly.
In chrome the home page loaded fine but when I click log in nothing happens.
In edge only the top banner loads (no animated joseph) and again log in does nothing.
Also tried from my work network and the same thing happens.
Postato : 30/10/2021 4:36 pm
crussty
(@crussty)
Utenti
Ditto
I was getting the same thing last night and a print just stopped several hours into a 2 day print. I was able to finally log back in this morning.
De do do do de da da da... Is all I want to say to you...
Postato : 03/11/2021 5:24 pm
Vlastimil
(@vlastimil)
Utenti
print just stopped?
That's bad news. There's no good reason an outage of prusa connect cloud service should stop the print, as the gcode is on the local prusalink device. It shouldn't even stop if it has issues with the local wifi.
I think if I was about to do such long print I would use the plain old SD card for now, and use prusalink only for monitoring. If it would stop due to cloud or wifi issues, it would be even worse in that scenario.
Postato : 04/11/2021 10:53 am
