Connect is printing queue items multiple times
henning
(@henning-2)
Recently, since maybe about 2/3/4 weeks(i dont print very regularly), i observe that connect randomly starts print jobs another time after they are finished.
It seems to happen mainly when I upload multiple items onto the device - either with the web form on the "printer files" tab or directly via slicer.
I first thought i made have made a mistake,. but it's now the third time that the quese isn't working properly and that instead of the next item in the queue fomr some reason the just finshed item gets printed again.
I also in the meantime double check the queue after each upload, but it always looks good - until i take out another finished object out of the printer, set it to ready again, and get to see that it isn't printing the next expected object but the last one again.
Does anyone observe a similar behaviour?
Napsal : 02/04/2025 5:51 pm
3 lidem se líbí
henning
(@henning-2)
RE: Connect is printing queue items multiple times
maybe this is the same as described here and seems to be known since quite a while but noone from Prusa seems to be willing to answer 🙁
https://forum.prusa3d.com/forum/bugs-errors/connect-is-printing-queue-items-multiple-times/#post-743704
Napsal : 04/04/2025 11:34 am
f_bohmann
(@f_bohmann)
i have the same issue. when uploading to prusa connect from the linux version of prusaslicer, stuff ends up in the queue multiple times, and sometimes at some time in the future, stuff that was printed before the current print gets schedules for the future again. it is really weird, as i could swear that slicers upload function told me it is going to be slot #2 in the queue when i uploaded it.
Napsal : 17/08/2025 7:56 am
RalfD
(@ralfd-2)
I also report this issue, when sending a print file to connect. I only use connect to send the files to the printer, and when I send one file to connect,
it appears twice in the printing queue.
When I do not remember this issue and set the printer ready, after finishing another job, the old file is repeated, instead of the new uploaded one.
Maybe it's also possible that the issue is addressed to the firmware (6.4.0 RC)
Prusa Slicer 2.9.3
Napsal : 12/10/2025 10:48 am
Cammy
(@cammy)
I have been suffering from the same issue for a couple of weeks now as well, I am currently running windows and a wired connection to my printer, and every time I send a print to it, even off the in-app slicer it will queue it twice. Hoping the fix it as it is a major inconvenience.
Napsal : 21/10/2025 9:18 pm
Lina Salamah
(@lina-salamah)
Same here.
I uploaded a new print, saw that it was uploading the CORRECT NEW file, so I left, and when I came back I found the previous file re-printing.
Waste of filament and time.
Napsal : 20/11/2025 7:03 pm
JJustra
(@jjustra)
Same here. Just looking at 58% complete of already printed part.
Napsal : 22/01/2026 8:09 am
JJustra
(@jjustra)
Seems to be fixed now. Kudos to devs 🙂
Napsal : 29/01/2026 3:30 pm
JJustra
(@jjustra)
Posted by: @jjustra
Hm, never mind - happened again o_O
Napsal : 31/01/2026 4:39 am
nbing
(@nbing)
Hey,
Does anybody know if there is a by fix now?
Happened to me just now as well…
Cheers, NB
Napsal : 19/02/2026 10:10 am
Same Old Shane
(@same-old-shane)
Member Admin
Just to give an update of the last issue with Prusa connect,
Service Update: Resolution of Connection IssuesSummary Last night, our services experienced a temporary disruption. We are pleased to confirm that all systems are now fully operational.What Happened The incident began with an unexpected database issue that caused a brief service interruption. As systems began to recover, a surge in automated reconnection attempts from customer devices created a high-volume traffic spike. This "retry storm" mimicked the patterns of a DDoS attack, leading to extended periods of high latency and connection failures.Our Response * Rapid Detection: Our supervising team was alerted by user reports and internal monitoring, triggering an immediate emergency response.
  • Mitigation: We implemented traffic shedding and resource scaling to stabilize the environment and process the backlog of requests.
  • Next Steps: Our specialists are conducting a full Root Cause Analysis (RCA) to identify the database trigger and implement new rate-limiting precautions to prevent similar "retry storms" in the future.
We appreciate your patience while our team worked through the night to restore your service.
Shane (AKA FromPrusa)
Napsal : 04/03/2026 1:18 pm
