Camera Feed Not Working. Showing Missing Image in Safari / Mobile Safari.
Brooke
(@brooke)
I am having trouble getting the camera feed to load when viewing from Safari on any of my devices. I have a USB webcam plugged in to a Raspberry Pi 3B. Image only shows up when using Arc Browser on my iMac, but does not show up using Safari on any of my devices. I am unable to see the camera feed from my iPhone regardless of browser choice, probably due to them all using Apple webkit. The issue occurs in both Prusa Link and Prusa Connect, though the small preview icon does show properly on Prusa Connect. Does anyone have a solution to this?
Opublikowany : 05/07/2024 9:41 pm
Brooke
(@brooke)
RE: Camera Feed Not Working. Showing Missing Image in Safari / Mobile Safari.
Edit: This is happening in Prusa Link 0.8.1.
Seems like it may be an issue with the way the image blobs are being rendered and some compatibility issue with WebKit.
Opublikowany : 05/07/2024 9:55 pm
OOS134
(@oos134)
I'm experiencing the same problem. The camera images are not displayed in Safari.
I read this post:
https://forum.prusa3d.com/forum/introcuctions-instrutctions/camera-thumbnails-not-loading-on-mac-and-ios-safari-browser/
My setup is a Pi 4B+ with a logitech C270. So i’m going to try another camera.
Opublikowany : 08/07/2024 9:20 pm
1 ludzie polubili
Brooke
(@brooke)
Seems like that definitely is part of the issue. But interesting that Prusa connect does render the image correctly in one section which leads me to believe there is a problem with how they are rendering the specific images that may be a bit deeper than just the camera being used being the problem.
Opublikowany : 11/07/2024 4:59 am
UloPe
(@ulope)
Yep, there's definitely something wonky with how the image is being rendered in the Prusa Connect frontend.
See this screenshot from within Prusa Slicer (which also uses Safari):
Since the small preview shows up, clearly the issue is not with the image but with something else in the page.
Opublikowany : 15/04/2025 10:34 pm
