Bed temperature has disappeared from PrusaConnect
I just checked on the status of a job and noticed, no green line for bed temperature. Also not showing in the popup.
I checked the LCD display on the Mk3S, and it's at the expected 90 degrees.
If I look at old jobs, the green line is there.
Opublikowany : 22/12/2022 4:31 pm
RE: Bed temperature has disappeared from PrusaConnect
What version of PrusaLink are you running, I think this is more issues coming together. I do not repeat telemetry if the value is unchanged, but if we drop the connection for a short time, the temperature isn't re-reported or perhaps the info gets lost. The new version sidesteps this by sending all info infrequently even if not prompted to. You can try the RC2 to see if it's fixed there.
Opublikowany : 03/01/2023 4:46 pm
