Bad chars in filename will break the prusa-slicer => connect => printer workflow
Having certain chars, at least a Colon in your stl filename will result in a (b)gcode filename with that char in it's filename.
Uploading that file to connect will work flawlessly, but the printer will not download that file.
It's stuck now.
Imho somewhere in that chain should be either an error that pops up, or that filename should be replaced with a working one.
Opublikowany : 25/07/2024 5:04 pm
