API Error when running gcode that contains only movement commands
Phrozen
(@phrozen)
Prusalink Type: Raspberry Pi Zero W
PrusaLink Version: 0.5.2
Printer Type: MK3S
Printer UUID:
Printer Firmware Version: 3.10.0-4481
PrusaSlicer version: n/a
Description: Receiving messages when running gcode that contains only movements (used for greasing the rods) of the x/y/z axis.  But printer continues to run as expected.
1. Load gcode from forum post https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-general-discussion-announcements-and-releases/lubricating-bearing-gcodes/
2. Start Print (PrusaLink)
3. Error: "API Error"; "Something bad happened on printer's side."
4. Print runs as normal
Opublikowany : 24/09/2021 3:42 pm
Nikomi
(@nikomi)
The same behavior
The same behavior when printing files from SD card from printer.
Printer Type: MK3S
Printer Firmware Version: 3.10.1-RC1-4587
PrusaSlicer version: 2.4.0 alpha 1
Opublikowany : 30/09/2021 4:25 pm
TimeMaster
(@timemaster)
Thank you guys, they didn't believe me a few weeks ago when I was reporting this for the first time 🙂
Opublikowany : 30/09/2021 7:54 pm
