5.1 Alpha 2 not connecting to Prusa Connect
bendrumin
(@bendrumin)
It seems like 5.1 Alphas are not supported with Prusa Connect (TLS error) Any update or workaround?
Opublikowany : 26/10/2023 3:37 pm
Tojik
(@tojik)
Member Moderator
RE: 5.1 Alpha 2 not connecting to Prusa Connect
Hi, try using Ethernet, there is an issue between the ESP board and the printer. Ethernet does not use the ESP, so it's not affected
Opublikowany : 26/10/2023 6:59 pm
