5.1 Alpha 2 not connecting to Prusa Connect
It seems like 5.1 Alphas are not supported with Prusa Connect (TLS error) Any update or workaround?
Opublikowany : 26/10/2023 3:37 pm
RE: 5.1 Alpha 2 not connecting to Prusa Connect
Hi, try using Ethernet, there is an issue between the ESP board and the printer. Ethernet does not use the ESP, so it's not affected
Opublikowany : 26/10/2023 6:59 pm
