0.5.2 Documentation missing for USB and non Zero Pi
Page 1 / 3
Eric E
(@eric-e)
Membre
Documentation should include the fact that other Pi devices do work, and can be connected via USB.
File /etc/Prusa-Link/prusa-link.ini
If the directory and/or file do not exist, just create 'em.  No biggie.
In that file, insert
[printer]
port=/dev/ttyACM0
baudrate=115200
This will enable communication via USB.
If you are feeling particularly neurotic, edit /etc/rc.local
printf 'M117 Starting Prusa Link\n' > /dev/ttyACM0
Above works perfectly for a Pi 4 & MK3S+
Don’t trust forum advice.
Publié : 18/09/2021 3:56 pm
tjmaxal, Momo, Tojik et 4 personnes ont aimé
sparkymarky800
(@sparkymarky800)
Membre
Problems with connecting to printer?
I can get the prusa-link local web page up, but it seems it's not connecting to the printer.
Are there any specific things to do when creating the ini file that I could've possibly missed?
Publié : 04/10/2021 6:43 pm
tjmaxal a aimé
Eric E
(@eric-e)
Membre
Try this
dmesg | grep tty
Look for something like this:
[ 5.155995] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
In my case, ttyACM0 (/dev/ttyACMo) as I wrote above, is the only tty device attached as USB.  That is the printer.  Most anything else USB attached will not be tty - just your printer.
Yours might be different?
And you setup with the character after ACM as a zero, and not the letter O?
Publié : 05/10/2021 9:05 am
House3D
(@house3d)
Membre
Trying to do the same
Hey, I am attempting to do this too with a Pi3. Are you adding the directory and ini file to the pi or to the printer?
I have attempted to add the [printer] command into the ini file inside the pi sd card and I still can't communicate with the printer.
Publié : 05/10/2021 9:26 am
Eric E
(@eric-e)
Membre
Yes
You create the directory and create the file on the Pi file system.
I don't have a Pi3, so I don't know, but do try the dmesg thing above.  Even if we are both running the exact same version of Raspberry OS, the different hardware - especially very different USB hardware, may lead to different naming.
Do you, for example, even have a /dev/ttyACM0?  If not... that might be a clue.
And, do confirm that the directory and .ini file are readable by everyone
Publié : 05/10/2021 9:52 am
sparkymarky800
(@sparkymarky800)
Membre
Success on Pi3
After much fiddling I can confirm this does work on the Pi 3.
Thanks for the info Eric E.
The problem for me was putting the file in the correct place. /etc does already exist, but for clarity you have to ssh into the pi to find it.
Publié : 05/10/2021 8:22 pm
Caveman
(@caveman-2)
Membre
RE: have the same problem
created file , prusalink boots up but can't connect
[ 0.001809] printk: console [tty1] enabled[ 1.438434] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2[ 3.159768] systemd[1]: Created slice system-getty.slice.[ 5.120656] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
these are my connected devices. I asume mine is ttyACM0
it connects somehow since my mk3s reboots when i reboot pi
Publié : 10/10/2021 2:32 pm
sparkymarky800
(@sparkymarky800)
Membre
Re: have the same problem
The fact that your MK3 reboots when you boot the pi does sound promising.
I would recheck the prusa-link.ini file on the pi to make sure the info from above is actually in there.
Publié : 10/10/2021 3:13 pm
Caveman
(@caveman-2)
Membre
Got it to work
did a reinstall on sdcard and now it works!
Publié : 10/10/2021 3:16 pm
madpro
(@madpro)
Membre
RE: 0.5.2 Documentation missing for USB and non Zero Pi
Confirmed that the above instructions work on PrusaLink version 0.6.0 also.
Note: please make sure you  >sudo su  before creating the new folder/file.
Note: once the file is added and you want to reboot - for beta try > sudo reboot --force --force
Note: If for some weird reason your printer does not register on PrusaConnect on first try - no need to start over. Delete the prusa_printer_settings.ini in the /home/pi folder and reboot the pi. It will start the printer registration sequence again for PrusaLink. Its a good idea to open https://connect.prusa3d.com and leave the tab open in the same browser you open http://prusalink.local/ . In the final registration step of PrusaLink if you have to log-in to PrusaConnect,  the registration menu goes away and you are left with nothing to register and PrusaLink in error mode for the web service.
Publié : 21/12/2021 2:11 am
DanielAttia a aimé
DomiTech3D
(@domitech3d)
Membre
Hi
I think iam stupid...
I installed Octoprint on a Raspberry pi 4 and installed it on my MK3S + via USB. This all works too.
Now I have got access to PrusaConnect and would like to use it. Since I don't have a Raspberry Pi Zero W, I would like to use this with my existing Raspberry Pi 4.
Now I came across your instructions. I created the folder and the file with the specified content via Putty: File /etc/Prusa-Link/prusa-link.ini
I have also adjusted the authorization so that everyone can read it.
How can I now connect the PrusaConnect web interface to my printer?
Thanks for the help.
Publié : 24/12/2021 8:31 am
DomiTech3D
(@domitech3d)
Membre
Problem solved. Had to install PrusaLink and not Octoprint. I have now run it on a Raspberry PI 3 and connected it to PrusaConnect.
GETTING STARTED – Introduction & Instructions – Prusa3D Forum (prusaprinters.org)
Publié : 24/12/2021 9:25 am
Askella
(@askella)
Membre
Works on Zero W and Software 0.6.0
Thanks
Posted by: @eric-e
[printer]
port=/dev/ttyACM0
baudrate=115200
Publié : 24/12/2021 3:03 pm
Bdogg75
(@bdogg75)
Membre
How do you create the .ini file?
Publié : 27/12/2021 3:30 am
DomiTech3D
(@domitech3d)
Membre
Connect with Putty via SSH and Create the File.
go to the Folder etc: cd /etc
Create Folder: mkdir Prusa-Link
Create File with: touch prusa-link.ini
Edit File with: nano prusa-link.ini
Past that in de File and Save -
[printer]
port=/dev/ttyACM0
baudrate=115200
reboot: sudo reboot
Publié : 27/12/2021 7:18 am
Kiwi et tjmaxal ont aimé
Eric E
(@eric-e)
Membre
Might need a sudo or two in there for mkdir and touch.  Otherwise spot on, nice post.
Publié : 27/12/2021 7:42 am
tjmaxal et DomiTech3D ont aimé
Schrotti
(@schrotti)
Membre
hey.
i cant connect via SSH. is there any option you need to activate on the sd card before using SSH?
Error Message: "Network Error: Connection refused"
Publié : 30/12/2021 6:25 pm
tjmaxal a aimé
DanielAttia
(@danielattia)
Membre
Yes, you will need to use the Raspberry Pi Imager software advanced settings to allow for SSH.
Posted by: @schrotti
hey.
Publié : 30/12/2021 6:58 pm
tjmaxal et Schrotti ont aimé
Bdogg75
(@bdogg75)
Membre
Is there an alternative to Putty for Mac users?
Publié : 30/12/2021 10:47 pm
Bdogg75
(@bdogg75)
Membre
Can you elaborate on "a sudo or two", I'm not the best with programming so I'm not sure how to do this.
Publié : 30/12/2021 10:49 pm
Page 1 / 3
