Core One Buddy Camera High Chamber Temperature
4nthonylin
(@4nthonylin)
My buddy camera for core one works flawlessly when printing PETG and other low temperature filaments. However recently while printing PC CF, chamber temperatures can reach upwards of 60C.
For these jobs, I have noticed that the buddy camera will stop sending snapshots and livestream would fail, it looks like it's still connected to my wifi just no longer updates. Has anyone else noticed this? Is this expected at higher chamber temperatures? Seems like a huge miss if the camera stops working while printing these types of filament. Might need to investigate in active cooling or external ventilation for the camera in this case!
Posted : 04/08/2025 6:18 pm
Mario
(@mario-5)
RE: Core One Buddy Camera High Chamber Temperature
Same Issue here. After some hours of printing PA, no Image from the camera. Unplugging the cam solved the problem. Have you found a solution ?
best regards
Posted : 10/08/2025 6:12 pm
Garfieldt007
(@garfieldt007)
Same here seems the camera has a temperature bug
Posted : 18/08/2025 10:29 am
Garfieldt007
(@garfieldt007)
Just wanted to mention the i have the mmu3 upgrade. Maybe this could change the airflow.
Posted : 18/08/2025 10:33 am
K5OZ
 K5OZ
(@k5oz)
Has anyone found a cure for the buddy 3D camera shutting down with high temperature prints (ASA)?   Mine shuts down whenever my chamber temperature gets to > 60 degrees for a few minutes.
Posted : 25/08/2025 11:09 am
LarGriff
(@largriff)
Maybe that explains why they’re giving them away now, free with a Core One.
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Posted : 29/08/2025 1:04 pm
K5OZ
 K5OZ
(@k5oz)
Considering that the Buddy cameras spec says 65 degrees C it just can’t take the Heat.  LOL
Posted : 29/08/2025 1:43 pm
Laura F Farrell
(@laura-f-farrell)
I'm having this issue also with PA printing. As you say its only when the temperature goes above a certain level.
Posted : 18/09/2025 3:19 pm
Roger Essig
(@roger-essig)
in the manual that comes with the camera it has 'Operating Temperature 18-38 Degrees Celsius'.
Posted by: @k5oz
Posted : 24/09/2025 5:16 am
NikolasZ
(@nikolasz)
This happens to my camera too on my CoreOne. Whenever I write in ASA or PC/PCCF and chamber temperature gets upwards 50-60 degrees Celsius, the camera stops. I can reset it by removing the USB-cable and re-insert it on the back, and it will work for a few minutes, in the high temperature, but after a while it will stop again.
Posted : 06/10/2025 6:55 am
