Anyone run into “this image is older than 1 hour” on their buddy cam?
machinefiction
(@machinefiction)
ntdesign
(@ntdesign)
RE: Anyone run into “this image is older than 1 hour” on their buddy cam?
This happens when the printer isn't running...then it stops the snapshots.
Posted : 20/06/2025 11:29 am
Urs L
(@urs-l)
My printer actual run's, but i have now the same problem. No picture from the two cam's wich are connected to my XL printer.
Posted : 18/08/2025 12:31 pm
Garfieldt007
(@garfieldt007)
Same here, this is the third topic about the camera stopping to work. Maybee someone @Prusa should put an eye on this.
Posted : 18/08/2025 1:19 pm
Alwin
(@alwin)
i have the same problem. restarting the buddy3d cam or pulling power does not change anything. i gues deleting and connecting as a new camera would solve this, but thats a real hassle if this pops up often ...
Posted : 18/08/2025 1:44 pm
have you chatted with Prusa support?
Posted : 18/08/2025 4:23 pm
andhson
(@andhson)
When mine did that today I found that it insisted to try to connect to an access point in another building, a poor WiFi signal can probably cause this. Once I convinced the thing to use the closes AP in the right building it is back to normal.
/Anders
Posted : 18/08/2025 9:20 pm
Yann Gloriau
(@yann-gloriau)
Same issue here. Each time i want to use the cam, I need to delete it from the app and then reset it. Sometimes, I canuse it for 2 daysm sometimes it is less than one hour. It seems that there is an issue somewhere.
If you need log, please tell m ehow to find them.
Regards,
Yann
Posted : 28/08/2025 1:16 pm
HowieT
(@howiet)
Hello,
has anyone a solution? Since today I have the same issue. The printer connects to the WLAN without any problem.
Regards,
Harald
Posted : 14/09/2025 2:07 pm
h1ghK0
(@h1ghk0)
Same Problem here.
Anyone with a Solution?
Greetings,
Posted : 16/11/2025 4:38 pm
RalfD
(@ralfd-2)
I had the Issue on the Core One cam with the new Firmware 3.1.2
with this Firmware the cam lost the wifi Connection After some time and i also get the Message that the Images is Older than 1hour
maybe there is also an Issue with the Firmware on the Buddycam3d.
i temporarly solved it by downgrading the Firmware to 3.1.1
Posted : 20/11/2025 8:06 pm
