Powering the Buddy3D Camera with MK4/MK4S Enclosure LED/Advanced Filtration PSU
[Solved] Powering the Buddy3D Camera with MK4/MK4S Enclosure LED/Advanced Filtration PSU
Pandemonium
(@pandemonium)
I have seen many posts about using the Buddy3D Camera for the Core One in the MK4 Enclosure. Unfortunately, there is no way to power the camera without a separate power supply. I also know there is an Extension Header on the LED/Advanced Filtration PSU board that will provide a 24VDC power supply.
Has anyone tried powering anything from this Extension Header on the Optional PSU Board? My thought is to connect this Extension Header to a 12VDC Buck Converter with a USB-C port to power a Buddy3D Camera from the LED/AFS PSU board already installed?
Napsal : 24/04/2025 5:39 pm
1 lidem se líbí
Jagawams
(@jagawams)
RE: Powering the Buddy3D Camera with MK4/MK4S Enclosure LED/Advanced Filtration PSU
Yeah, that would be a feasable sulution - the cable provided with the camera is quite short.
The camera is a quite disapointing product...
Napsal : 29/05/2025 3:24 pm
1 lidem se líbí
