Buddycam Access SD Card
Ckobar
(@ckobar)
Hi, does anybody know how to access the sd card files remotely to retrieve the timelapse pictures.
thanks
Opublikowany : 11/07/2025 2:47 pm
1 ludzie polubili
RE: Buddycam Access SD Card
I don't think there's a remote access method. Gotta remove it manually and plug into your computer.
Opublikowany : 11/07/2025 8:50 pm
Zukke
(@zukke)
WHY is that? Why isn't there any possibility to access it remotely. This is such a simple requirement (at least from user perspective). Taking the SD card out manually is so inconvinient. Are there plans to implement this functionality, or is there a technical blocker?
Opublikowany : 01/12/2025 11:31 am
1 ludzie polubili
neuromorph
(@neuromorph)
I would also be very interested in this feature being implemented. Given that the camera is talking to PRUSA CONNECT and exchanging data, why not allow for the copy of files to the local computer?
Opublikowany : 26/12/2025 4:00 pm
_KaszpiR_
(@_kaszpir_)
there's really low memory available when the camera takes images and streams in the same time, so probably they would have to implement some mechanism to enable file  access over the web when streaming is not available, or run other service
Opublikowany : 21/01/2026 3:23 pm
