Buddy Camera in the Core one reads the code and shows up in Connect, but is not registered.
Dik Harrison
(@dik-harrison)
My Core One Buddy Camera was working fine until the last update. Now it reads the QR code, and it appears in Connect for the printer, but it is not registered.
I am using the same WIFI setup that worked before the update (i.e., no special characters in the SSD [only letters, -, and _] and only letters in the password. I have reset the camera to factory settings, and when the code is read, the new male voice says the code was recognized. Nothing else happens at either the camera or in Connect, other than the new camera showing up as unregistered.
Postato : 31/08/2025 1:01 pm
Dik Harrison
(@dik-harrison)
RE: Buddy Camera in the Core one reads the code and shows up in Connect, but is not registered.
That is correct. Any suggestions?
Postato : 17/09/2025 11:26 am
Crisendo
(@crisendo)
Utenti
I am having the same issue! Hope there's an answer to this
Postato : 29/09/2025 9:12 pm
KyleL
(@kylel)
Utenti
Same. I worked with support several months ago. They gave me an early release of the updated firmware but the issue persisted. They then sent me a replacement camera but the behavior is the same.
At this point I've given up on it, which is really disappointing. I have a ring cam pointed at my printer, but I really want the chamber camera that I purchased to work as described.
Postato : 14/10/2025 6:50 pm
