The screw is loose and the fan cannot be tightened.
5. E軸取付 ファン取り付け時に(STEP27)ネジが一箇所緩んでいてネジが締め付けられない場合はどうすればいいですか?(
Questa discussione è stata modificata 4 years fa da YKK2022
Postato : 09/07/2022 3:23 pm
RE: The screw is loose and the fan cannot be tightened.
The nut is in the fan shroud.
So when you fit that, you should be able to tighten everything
Regards Joan
Postato : 09/07/2022 5:04 pm
Step 43: https://help.prusa3d.com/guide/5-e-axis-assembly_169235
Postato : 09/07/2022 10:36 pm
Topic starter
answered:
thank you for your answer. It ’s okay because it ’s tightened with three screws. 😀 👍
Postato : 11/07/2022 2:09 pm
