The screw is loose and the fan cannot be tightened.
YKK2022
(@ykk2022)
5. E軸取付 ファン取り付け時に(STEP27)ネジが一箇所緩んでいてネジが締め付けられない場合はどうすればいいですか?(
This topic was modified 3 years temu by YKK2022
Opublikowany : 09/07/2022 3:23 pm
RE: The screw is loose and the fan cannot be tightened.
The nut is in the fan shroud.
So when you fit that, you should be able to tighten everything
Regards Joan
Opublikowany : 09/07/2022 5:04 pm
YKK2022
(@ykk2022)
Thank you for your reply. There are no nuts here. The hole in the self-tapping part is too large to tighten the screw. The screw at the bottom of the photo.
Opublikowany : 09/07/2022 10:09 pm
TheLivingBubba
(@thelivingbubba)
Step 43: https://help.prusa3d.com/guide/5-e-axis-assembly_169235
Opublikowany : 09/07/2022 10:36 pm
YKK2022
(@ykk2022)
thank you for your answer. It ’s okay because it ’s tightened with three screws. 😀 👍
Opublikowany : 11/07/2022 2:09 pm
