Power not turning on...
Strona 1 / 2
David Stephenson
(@david-stephenson-2)
So this is my third enclosure and first problem, when I turn the power on the little LCD monitor at the front does not turn on.
How do I go about troubleshooting this one?
The wires all seem to be attached properly to the PSU.
Best Answer by René:
Check whether there is 5V on pins 1 and 2 of connector P1.
If so, check whether this 5V is also present at the end of ribbon cable 1.
Opublikowany : 24/01/2023 11:10 am
Hello
(@hello)
RE: Power not turning on...
Does the light on einsy turn on
Opublikowany : 24/01/2023 8:38 pm
1 ludzie polubili
René
(@rene-3)
Are the two ribbon cables connected to the correct connectors?
The cable with one black band on EXP1 and the cable with two black bands on EXP2?
Opublikowany : 25/01/2023 7:44 am
1 ludzie polubili
David Stephenson
The light on the einsy turns on, the ribbon cables are inserted correctly into the back of the display (one band to exp1, two bands to exp 2)
This post was modified 3 years temu by David Stephenson
Opublikowany : 25/01/2023 8:36 am
Hello
(@hello)
How olds printer if it's less then a year old contact prusa on live chat as it might be faulty lcd also check contrast knob on back of lcd
Opublikowany : 25/01/2023 8:41 am
David Stephenson
Sadly I think this one is over a year old, worked perfectly before I put it in the enclosure... may need to try and source some ribbon cables to see if that is the problem.
Though I am intrigued by the contrast knob, I've not noticed one before.
Opublikowany : 25/01/2023 12:49 pm
David Stephenson
Is it possible that the ribbon cables could be the source of failure...
Opublikowany : 25/01/2023 12:53 pm
Hello
(@hello)
It is possible but unlikely that both are to fail normally the backlight still turns on I'm wondering if the heat from in the enclosure is effecting something have you take out of enclosure to see also if you touchd the einsy or the lcd static discharge can happen and frie the lcd
What I want you to do is scroll down by guessing using the nob to where you think preheat is and click it if it starts heating up it's bad lcd
Opublikowany : 25/01/2023 9:00 pm
1 ludzie polubili
Hello
(@hello)
Also when you click there is normally a noise if this happens the contrast has been changed or bad lcd
Opublikowany : 25/01/2023 9:02 pm
1 ludzie polubili
David Stephenson
I'll have a look at both of those tomorrow, I was earthed the whole time I was working with the enclosure so hopefully static will not have taken out something expensive
Opublikowany : 25/01/2023 9:41 pm
Hello
(@hello)
It's not about being earth for static electricity if you touch top screw of PSU it will take away static I always do this.
Opublikowany : 25/01/2023 10:07 pm
David Stephenson
The good news is the LCD is not fried, I plugged it into another unit with no problems, so still having the same issue with this unit though.
What is the next probable cause?
Opublikowany : 26/01/2023 3:45 pm
René
(@rene-3)
The first thing that comes to my mind is that one or both ribbon cables are causing a problem.
Opublikowany : 26/01/2023 4:05 pm
1 ludzie polubili
Hello
(@hello)
You said you pluged it into another unit so use theme ribbon cables
Opublikowany : 26/01/2023 11:44 pm
Hello
(@hello)
It could also be the einsy
Opublikowany : 26/01/2023 11:45 pm
1 ludzie polubili
René
(@rene-3)
Opublikowany : 27/01/2023 7:13 am
René
(@rene-3)
Posted by: @david-stephenson-2
To measure is to know, our teacher always said,
so it's time to start using the multi-meter 😊
Opublikowany : 27/01/2023 7:26 am
1 ludzie polubili
David Stephenson
Time to dig out the multimeter, good idea and I'll let you know how it goes.
Opublikowany : 27/01/2023 9:01 am
René
(@rene-3)
I (we) are waiting for the solution to your problem, so we can learn from that.
Opublikowany : 27/01/2023 3:01 pm
1 ludzie polubili
David Stephenson
I'll be grabbing my multi-meter from storage at the weekend ready for work on Monday, looking forward to having this up and running again!
Opublikowany : 27/01/2023 3:29 pm
Strona 1 / 2
