Issue with XL enclosure interfering with spool holders for multi tool XL
J3 Steel
(@j3-steel)
Utenti
My problem is, I currently have a 5 head XL with enclosure. My current spool locations are to use the included spindles. For 5 spools, one side of my printer needs to hold 3 spools. That does not leave enough room to put 3 spools and not have one of the 'lift tab'(or wing or whatever) of the enclosure curtain frame hit the spool spindle. This prevents the top frame of the enclosure curtain from engaging the magnetic catch.
Currently, I either have to print with a maximum of 4 spools, or I can't use my enclosure.
I have not found an alternative spool mount that would work mounted to the XL frame.
This seems extremely silly. What am i missing?
(p.s. I am currently designing a stand for my XL that would move the spools from the frame, but after using the machine for a while, I realize I need to adjust my plans because what I originally envisioned would conflict with good filament paths for the XL.)
Postato : 18/03/2025 7:13 pm
Brian
(@brian-12)
RE: Issue with XL enclosure interfering with spool holders for multi tool XL
Some pictures showing your dilemma might help.  Is this the Prusa enclosure your talking about?
Postato : 19/03/2025 3:19 am
