Filament tangling every time when using the enclosure with Prusa PLA
When using the purusa enclosure and prusament PLA, the filament is tangling with every roll tried (3 so far). It appears that the tension and wind memory in prusament PLA is affecting the unwind of the material given the location of the entry into the Bowden tube. at the start of the roll the binding sorts itself out but as the roll gets about 1/3 of the way through the binding becomes so severe that it causes the filament to break or the print to fail. Is there any solution to this out there?
Opublikowany : 19/04/2024 10:53 am
