[Gelöst] Adjust doors
sh4q
 sh4q
(@sh4q)
Adjust doors
Is there any possibility to adjust the doors of the Enclosure? My left door is round about 5mm lower than the right one.
Veröffentlicht : 12/09/2023 3:04 pm
ScottW
(@scottw)
RE: Adjust doors
I can't think of any reason these would be so far off.  The frame is self-squaring, and the holes are all precision cut.   If your doors are 5mm off, it makes me think either something is assembled incorrectly or the parts had some error in manufacturing.   Maybe the holes were drilled wrong on one of the vertical pieces?  Some pictures might help someone here spot the problem.
Veröffentlicht : 13/09/2023 4:08 pm
Chris Hill
(@chris-hill)
RE: Adjust doors
This is easily fixed.  The frame squares itself fairly well, but if it's been leant on it may have become distorted - you just need to 'lean' it back.  So if your left door is too low, just put your left hand on the bottom left corner of the enclosure, and your right hand on the top right corner, then squeeze your hands together until the doors line up.
Veröffentlicht : 13/09/2023 5:05 pm
sh4q
 sh4q
(@sh4q)
RE: Adjust doors
Thank you!! I thought this is impossible but it was zur solution. Maybe happened during transport.
Posted by: @chris-hill
Veröffentlicht : 15/09/2023 6:45 am
Ckobar
(@ckobar)
RE: Adjust doors
works even better, if you loosen the "corner- screws" of the frame (facing towards you) . Than you can adjust it very percise and easy.
Just did this the other day after moving my enclosure to another table.
Veröffentlicht : 20/09/2023 6:33 am
IanY
 IanY
(@iany)
RE: Adjust doors
Thanks so much.  I should have check this forum first.  I had assembled and reassembled the doors upside down and switched around.  Your instructions did the trick.
Veröffentlicht : 29/10/2023 2:52 am
IanY
 IanY
(@iany)
RE: Adjust doors
Chris. If you don't mind I will copy your post to the assembly instructions.  I noticed that the door assembly is missing from the instructions but if it was there your steps should be the final step to align the door properly.
Veröffentlicht : 29/10/2023 3:51 am
Chris Hill
(@chris-hill)
RE: Adjust doors
Posted by: @iany
Thanks Ian - it's cool that you've done that.
Veröffentlicht : 31/10/2023 5:29 pm
Jason Englert
(@jason-englert)
RE: Adjust doors
I also have this problem. As I don't have the handles installed and my printer is not easy to move. I most like skewed it because of this, as was suggested. I will try to fix it per these instructions and report back.
Veröffentlicht : 28/01/2024 9:52 pm
