A few things to consider when assembling your Prusa Enclosure
IanY
 IanY
(@iany)
Here are a few things to consider when assembling your Prusa Enclosure.
1. You don’t have to disassemble the MK4 printer and can keep the power supply and LED display attached.
2. If you do this you will want to use the hinged lid so that later you can easily remove the printer if needed.
Hinged lid for adding MMU2S to Original Prusa Enclosure
https://help.prusa3d.com/guide/6-hinged-lid-add-on_354154
https://www.printables.com/model/273426-hinged-lid
3. If you remove the side cutouts then the handles will have to be printed.  They are not shipped with the enclosure.
Transport handle for Original Prusa Enclosure
https://www.printables.com/model/252904-transport-handle-for-original-prusa-enclosure
4. If you decide to place your spool on top of the enclosure such as printing with a dryer box then you may want to print the filament guide. This print is a bit thigh and will need to be printed with XY size compensation = -0.09.
Filament Guide and Holder Prusa Enclosure
Adjust the XY size compensation = -0.09
https://www.printables.com/model/554176-filament-guide-and-holder-prusa-enclosure
Postato : 29/10/2023 4:36 am
