Z offset help, setup of mini
angelblade
(@angelblade)
Hi Gang,
First post here.  I've been printing for about one year so I am familiar somewhat with the trials and tribulations of printing.  I am however a bit shocked as I just set my Z offset to -2.00 and it won't go any further.  My concern is it wasn't assembled properly and what I should do next if I need to move the extruder further down.  Can someone comment if a -2.00 is normal?  It started 1/3 printing the benchy ok, but then came off the plate later on in the print so I think I need to move the extruder closer to the bed.  I would appreciate any help.
Thank You,
Chris
Napsal : 05/01/2023 11:26 pm
1 lidem se líbí
angelblade
(@angelblade)
RE: Z offset help, setup of mini
I'm getting even more nervous that nobody has responded.  Can someone tell me what they set their mini offset too so I can compare?
Napsal : 06/01/2023 7:01 pm
I don't use Z offset, If the live Z setting is too large, I reset the live Z to zero, then  move the Pinda / Supa Pinda a little further from the build plate the pinda thread is 8mm diameter x 1mm pitch if you slacken the clamp a little and move the pinda 1 thread up then re tighten the clamp, that should reduce the live Z by 1mm, making it easier to adjust live Z
None of my 4  Prusa printers use Z offset!
Napsal : 06/01/2023 7:24 pm
1 lidem se líbí
angelblade
(@angelblade)
Joan,
Your words of wisdom are amazing.  Thank you so much for your thoughtful post!
Napsal : 06/01/2023 7:58 pm
I hope wisdom translates to success...
the Pinda positioning is a bit confusing, in that you move the pinda away from the build plate to make live Z values smaller.
best wishes,
Joan
Napsal : 06/01/2023 11:25 pm
1 lidem se líbí
GSKR
 GSKR
(@gskr)
Thank you so much for caring and sharing this.💛
It worked a treat. Blessings✨
Napsal : 14/07/2025 2:31 am
