Z-axis fine during calibration - but during print it is 5 mm above the plate
NISB
 NISB
(@nisb)
Hi all
Well, the title says it all.
When calibrating, all is well. When I then try to print, the nozzle is 5mm up in the air.
Any suggestions how to fix this?
Was working fine till yesterday...
Veröffentlicht : 06/02/2022 6:59 am
Mitglied
RE: Z-axis fine during calibration - but during print it is 5 mm above the plate
Did you adjust your pinda probe height?
Veröffentlicht : 19/02/2022 1:41 pm
NISB
 NISB
(@nisb)
Hi
I did. It was a bit high, so I have moved it a bit down.
I did a First Layer Calibration afterwards, but do I need to do some kind of Pinda-calibration as well...?
Veröffentlicht : 19/02/2022 3:33 pm
Stobal
(@stobal)
It sounds like maybe the z value after you moved the sensor didn’t get saved for whatever reason. Have your tried odd running a new first layer calibration. Maybe start the z value from zero to check is the value gets recorded.
Veröffentlicht : 05/03/2022 7:38 pm
