z-axis : even at -2.000 it's still too high 🙁
Michiel Bontenbal
(@michiel-bontenbal)
My new mini+ has a z-layer calibration issue. It's nozzle is simply too high. Even when I adjust it to -2.000 it's still too high.
What should I do? Thanks
Respondido : 05/03/2021 2:44 pm
Loak
 Loak
(@loak)
RE: z-axis : even at -2.000 it's still too high 🙁
Hi @michiel-bontenbal,
Have you followed the fist step of this ? Anyway your SPINDA probe need to be  upper, about 1 mm (maybe more) higher to keep the margin if you use different sheets of steel (PEI, textured, satin ...).
MK3s Stock, PS2.3, Fusion360, Debian, Windows 10.
Respondido : 05/03/2021 3:08 pm
Dan Rogers
(@dan-rogers)
So go more!  My Z is -520 on my smooth sheet for "high starting point:
Respondido : 05/03/2021 3:16 pm
Oxygen
(@oxygen)
If you take the advise of Loak, and you still have a LiveZ above the 1900 then do the re-calibration of the SPINDA with a higher value then the zip-tie (=0.8mm) I have taken a bigger zip-tie (1.2mm) and calibrated the probe with that (my Z value is now -950 for the smooth sheet)
Stock MK4S with FW 6.2.6
Respondido : 05/03/2021 3:22 pm
Michiel Bontenbal
I indeed did a much higher SPINDA => 2 bank passes ;-). That worked. (However, new problem => new post). Thanks for helping me out !
Respondido : 06/03/2021 4:48 pm
