Z-axis calibration
dnkcz
(@dnkcz)
Z-axis calibration
Hi for some reason, Z-axis calibration is failing.. i read  there should be 185mm length, Z axis is moving ok i guess.. but it ends at 181. I applied lube . Maybe in the middle section when i do Control - move Z axis from top to down or down to top, there are bit weird noises (just a little bit, not sure if that can be the problem).  Thanks in advance
Postato : 11/07/2024 5:35 pm
