z-axis calibrate value
atomleef
(@atomleef)
what is your z-axis calibrate value? In which plate? smooth, texture. mine is -0.82 what yours?
thank you
Opublikowany : 18/03/2020 5:16 am
kennd
(@kennd)
RE: z-axis calibrate value
This a question where any value anyone posted is only of value to the person that posts it. Every printer is different and therefore all values can be different. If I was to post a value of -0.983, you cannot assume it will work for you. And if you tried it you could end up buying a new sheet and possibly a nozzle.
If you are having a problem, then explain it here and maybe someone can help you. Are you having first layer issues? adhesion issues?
Quality is the Journey, not the Destination. My limited prints->
Opublikowany : 24/03/2020 9:00 am
Posted by: @atomleef
thank you
That depends on the height setting of the PINDA and the type of printing plate and is certainly different for every printer. If the height is not correct, you have problems with the the first layer when printing.
Opublikowany : 24/03/2020 9:29 am
