Y Belt Idler issue
Macmagoo
(@macmagoo)
Y Belt Idler issue
I started my build today however, I never got very far. The Y belt Idler or the front plate has the holes in the wrong place. The distance between the holes and the front plate and the holes on the plastic piece are different distances apart. The printer is the MK3S+ and I am following the manual V3.21 supplied with the printer.
Opublikowany : 02/01/2021 9:56 pm
RE: Y Belt Idler issue
Posted by: @loopman
I suspect that Prusa has sent you a wrong part. I would take a photo of both parts and contact the Prusachat (Log in with your account and select the eshop. adblocker should be disabled).
Opublikowany : 02/01/2021 11:19 pm
Macmagoo
(@macmagoo)
@karl-herbert
Thanks I will try that tomorrow.
Opublikowany : 02/01/2021 11:24 pm
