y axis problem
tw007
(@tw007)
y axis problem
Help, when I try to print, my printer does the 9 point calibration but then it rises up to about 4 inches, goes to the right and stops 3 inches from the right.
Napsal : 18/10/2021 9:24 am
BogdanH
(@bogdanh)
You will need to tell more than that to get some help. How old is printer? You printed successfully before? You tried to print some different object? etc.etc. In short: we know nothing about your situation.
[Mini+] [MK3S+BEAR]
Napsal : 18/10/2021 11:41 am
tw007
(@tw007)
Trouble with first print
Hi,  Sorry it's the X axis I'm I am a fist starter with 3D printers, My printer is a brand new MK3S+  kit . My issue is, It does a 9 point check and then it rises and travels to the end of the x axis and not the Y axis, then it stops.
Set up  -  Preheat PLA,  Autoload Filament at 215/60,   print from SD   Stops at end of X axis and not the Y Axis. it beeps to press the knob to unload the filament.     and that's it    (  it did not do the self test where it lays beads of filament ).
Napsal : 19/10/2021 2:49 am
