X , Y motor temperature
Ahmad
(@ahmad)
i have new Prusa mini, i face a lot of problem in the beginning, first leveling calibration, and other problem, i fix all the problem and change a lot of spare part including the new super PINDA sensor. but after i start printing the Benchy model i notes the motor temperature of X axis and Y start come hot. the model start damage. i m not sure is it normal or i need to change also the motors. also i notes the belt of X axis damaged.
Respondido : 16/12/2020 6:51 pm
RE: X , Y motor temperature
Posted by: @ahmad
Hello and welcome to the Prusaforum!
First of all, congratulations for the patience applied to the numerous problem treatments.
The steppers should not normally get so warm that you can hardly touch them. Are the axles smooth-running? They should move easily in all directions and not have any obstructions. I would also check the electrical system connections again.
Respondido : 16/12/2020 9:08 pm
