Wobbely Mini+
Rien
 Rien
(@rien)
Wobbely Mini+
I just received and assambled my Mini+, the problem is that it's 'wobbely'.
I put 4 foam-pads on the XZ-axis as shown in the manual and the YouTube instructions.
The problem is with the 5th foam-pad. It sits under the electronic-box but it's not on the same level with the other foam-pads. So, my printer is not stable.
Napsal : 04/05/2021 3:08 pm
mrstoned
(@mrstoned)
RE: Wobbely Mini+
I had a similar problem when removing the buildplate that it would lift the whole printer towards the rear and right.
I printed and put https://www.prusaprinters.org/prints/44643-prusa-mini-power-plug-stress-relief and now it is rock solid.
I guess it depends a little on how the bridging is on the slot for the foampad on the electronics box.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
Napsal : 05/05/2021 11:41 am
Rien
 Rien
(@rien)
RE: Wobbely Mini+
@mrstoned
Thanks for this solution. I will print it this weekend (my first print!) and hope it's the solution.
Napsal : 05/05/2021 1:36 pm
RE: Wobbely Mini+
@mrstoned
Great addition.  I will also print this tonight.  V
Napsal : 05/05/2021 5:11 pm
Ernie Tech
(@ernie-tech)
RE: Wobbely Mini+
My experience as well. Thanks for the fix. Will print this soon.
Be the Denisovan in the sea of Neanderthals
Napsal : 26/05/2023 4:11 pm
Tysonsw
(@tysonsw)
RE: Wobbely Mini+
Are you sure that you put the foam foot in the correct slot and that your electronic box is on the correct level?
My Mini+ sits completely flat with all five feet.
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: [email protected]
Napsal : 29/05/2023 11:53 am
Ernie Tech
(@ernie-tech)
RE: Wobbely Mini+
Yup. Certain
Napsal : 30/05/2023 1:04 am
Andarne
(@andarne)
RE: Wobbely Mini+
Bought two used Mini+ off of eBay and noticed quite a wobble in them both with the foam pads, so I went and installed these on both: Prusa Mini Support Legs
The wobble has mostly gone, I think some tiny adjustments on my end are still needed.
Napsal : 03/08/2023 11:18 am
RE: Wobbely Mini+
Odd, my Mini+ did not come with foam pads.  My Mini also did not.  My two Chinese knockoffs did.  Check to make sure you received a real Prusa printer and not a clone.
Posted by: @andarne
Napsal : 03/08/2023 12:14 pm
René
(@rene-3)
RE: Wobbely Mini+
Check that the pads are attached in the right place.
They should be glued to the aluminum profiles.
So not on the front and back part.
Napsal : 03/08/2023 3:22 pm
