Vertical line across prints
Hi, I just bought my first 3D printer Mini+ and with every print I am getting a strange vertical line. This happens only with items I designed in Fusion360, but they don't occur on test prints, like the whistle. Any idea on what am I doing wrong and how to remove this? I am new to the world of 3D printing so any help is appreciated.
Thanks
RE: Vertical line across prints
That is a seam
Typically slicer hides seams in corners. But there are not many corners in a circle.
You can adjust the retraction settings to reduce seams and try random seams to reduce the effects
Regards Joan
dukicn, see this article for a great explanation:
https://help.prusa3d.com/article/seam-position_151069
Thank you both. Setting seam to random helped, it is almost invisible.
