[Resuelto] Uneven line during first layer calibration
Mryck
(@mryck)
Hello all,
I currently have an issue with one of my minis with was running fine for years that I don't know how to solve:
I notice some gap in thin wall (2 perimeters) on one side of the print, so I did the first layer calibration to see if everything was ok and I noticed that line going from right to left were larger than line from left to right.
I then did a calibration cube to check the layer width and on the 20x20 vase cube I have .50mm on the left and .35 on the right side.
The PTFE heartbreak tube is new same as the nozzle, I do maintenance regularly as it prints almost every day.
Does anyone have an idea from where this issue can come ?
Thanks
Best Answer by Mryck:
So after searching on internet everything around this issue, I found the problem it came from the Extruder-Hotend PTFE tube which was all worn out I guess from the filament sliding inside and the left-right movement. I try with another one and everything looks good now.
Problem solved !
Respondido : 05/03/2023 1:53 pm
JMH714
(@jmh714-2)
RE: Uneven line during first layer calibration
Bed level may be different in center??
Respondido : 05/03/2023 5:22 pm
Mryck
(@mryck)
Problem solved !
Respondido : 06/03/2023 8:34 pm
mitchkramez
(@mitchkramez)
Miembro
@Mryck - are you referring to the longer tube that goes from the extrude to the hot-end or the short tube inside the hotend?
Respondido : 24/04/2023 9:03 pm
