Underextrusion proof with cold pull
I still have under-extrusion issues with my mini and thought I would give this a try prusa mini cold pull method but when I removed the filament for the 3rd time I noticed the 'notch' pointed by the red arrow. Do I need to worry about this? or is this a different thing?
Mini with FW:4.4.1 + SuperPINDA + Bondtech Heatbreak + PC4-M8 couplers + 1 piece boden
RE: Underextrusion proof with cold pull
The thing is that the same effect is shown on the link of the cold pull instructions but on a different height. It is probably due to the force that you put by pressing the filament in. I think if the thickness is lower than 1.75-1.9mm its not something to be alarmed about.
Original Prusa Mini + Smooth PEI
Prusa Slicer 2.6.0
